Glad to hear that the rear spring install went well. Man, the rear does sit kinda high, though. I'm guessing these were cargo coils.
As for doing the fronts. You'll need a good floor jack, jack stands, coil spring compressor, ball joint and tie rod pickle forks, and a decent set of wrenches, ratchet and sockets, torque wrench.
I would advise you to read up about doing the procedure in a good manual before attempting it. It can be a dangerous job if care is not exercised.
Using a piece of chain, or cable thru the spring and control arm, and bolted together while you're lowering the jack. Just alittle safe guard incase the spring lets go. Guys who have done this job numerous times would know how to handle the jack effectively.
