I have the stock moog 5379 in rear and 5660 in front. Its slighty raked but nothing drastic I like the lookWhich moog springs are you running? Is it stock height?
I don't remember what bracing the '79 GP has behind the back seat, but T-top cars cars can really benefit from a XX brace made out of electrical conduit bolted to the body behind the seat, Cutlass jounce bars to go with a GP bar to stiffen the frame in front and makes sure you have all of the lower body bushings.
All the same...Thanks guys. Looking through the options for adjustable rear upper control arms are these compatible with the 7.5 rears or are they just for the 8.5?
Will the 1 inch drop springs in the rear make the car look as if its sag, as I wont be able to set up the front end this season so it will remain with the stock coil spring and control arms.Here is my input on this, If your not out thrashing your car on autocross tracks or on the back roads then coilovers are over kill. I would suggest UMI 1 inch drop springs with bilsteins all on four corners. Is your car a F41 package car? I'd assume since it has the rear bar already.. but going to a 1 inch from 7/8 might help a tad, what will make a big difference is the adjustable frame and rear axle mounted sway bar. The list could go on and on... it all depends what your plans are with your car.. Good luck it gets very pricey quick!!
