Recent upgrade
And in that year its useful life has been used up 😮. I wish you the best but usually even “built” 60E’s fail miserably. You can’t always fix small diameter input shafts and weak internals with metallurgy.
Ill be sure you keep you posted.
Reactions: L92 OLDS
Time for an update. Only a few item left to do on the supercharger install. Finish up the intercooler lines and mount the pump. The trans is moving along. I decided the est option for me was to build it myself. Sonnax parts sure a expensive. Billet shafts, and the addition of 5 pinion planets along with many other upgrades should be sufficient for the power levels.
