dlo253 said:
Clone TIE Pilot said:
Alot of places say black lasts longer than red. Avoid poly bushings with graphite in them, all the graphite does is make the bushing weaker.
Alot of places say they are better, yet they are weaker??
Well with everyone bickering about who is right all the time, it's awfully hard to learn anything. Until someone can find several instances that prove they are weaker, I wouldn't assume they are. Same thing with the body bushings with the metal sleeve/collar inside- unless someone can find several instances and scientifically prove they cause the frame to rust out, I wouldn't assume they do. Based on all the discussions on body bushings and hardware between clone, GP, Fox80, Jack, Blake442, and countless others on this forum I've concluded that it's best to go with the Energy Suspension Bushings (either color) with the metal collar inside and the 10.9 bolts with antiseize torqued to 52 ft lbs.
Also, did anyone ever find out if these
specific bushings even
even graphite in them? After all Energy says "certain" bushings have graphite in them.
