GM ought to have put the rubber bushings in a sealed bags to prevent oxygen from degrading the rubber....
Clone TIE Pilot said:Going from my own experience, every rubber body bushing in my car had rusted inserts. They were all seperating from the rubber and in much poorer shape than the rubber itself. One of my old bushings the insert was gone, rusted completely away taking the frame mount with it, but the bushing still looked fine from the outside, no cracks or splits. At least for me, the molded in inserts were the most deteriorated part of my old bushings. It is a very known fact that rust spreads from bad metal to infect good metal, that is how it creeps under paint and other coatings. IE, rust spreads from the inserts to the frame mounts since they are in direct contact. Researching body bushing replacement online, I have seen that every posted photo of old rubber bushings shows them having rusting inserts seperating from the rubber. Many have posted about a pile of rust coming out of the old bushings when they are removed. It seems to be a pretty common phenomenon going by all the postings online about body bushing replacement showing rusting inserts and . Perhaps Energy Suspension rust proof their inserts better than GM did, but I didn't want to take the chance and choose bushings without inserts. Here is one post about a Ford Explorer body bushing hardware rusting out http://www.explorerforum.com/forums/showthread.php?t=292471&page=2 Here is another example of rusty bushing inserts in a Jeep, http://www.jeepforum.com/forum/f8/kens-1985-cj7-refurbishment-thread-1040550/index102.html.
I do not know if that model number of Enegry Suspension bushings are polygraphite bushings, it was a general remark about polygrapite bushings. Not all black poly bushings have graphite, but I guess some brands may use color to denote if they are polygraphite or regular poly. I have seen red poly bushings with graphite swirls in it. My black poly bushings don't contain graphite.
joesregalproject said:Clone TIE Pilot said:Going from my own experience, every rubber body bushing in my car had rusted inserts. They were all seperating from the rubber and in much poorer shape than the rubber itself. One of my old bushings the insert was gone, rusted completely away taking the frame mount with it, but the bushing still looked fine from the outside, no cracks or splits. At least for me, the molded in inserts were the most deteriorated part of my old bushings. It is a very known fact that rust spreads from bad metal to infect good metal, that is how it creeps under paint and other coatings. IE, rust spreads from the inserts to the frame mounts since they are in direct contact. Researching body bushing replacement online, I have seen that every posted photo of old rubber bushings shows them having rusting inserts seperating from the rubber. Many have posted about a pile of rust coming out of the old bushings when they are removed. It seems to be a pretty common phenomenon going by all the postings online about body bushing replacement showing rusting inserts and . Perhaps Energy Suspension rust proof their inserts better than GM did, but I didn't want to take the chance and choose bushings without inserts. Here is one post about a Ford Explorer body bushing hardware rusting out http://www.explorerforum.com/forums/showthread.php?t=292471&page=2 Here is another example of rusty bushing inserts in a Jeep, http://www.jeepforum.com/forum/f8/kens-1985-cj7-refurbishment-thread-1040550/index102.html.
I agree that the factory inserts rust out but I disagree that rust is contagious and that the rust from the insert spreads to the frame. I rather think water sits around the bushing and causes the frame and insert to rust, but the rusting of the frame starts at the frame and the rusting of the insert starts at the insert. Also I do not believe that poly alone is strong enough to support the weight of the body over time without an insert and that is why I went with the Energy Suspension kit. And yes the Energy kit's hardware is all zinc plated.
Personally I believe that even if these inserts do rust out, by the time they do, the solid poly bushings without an insert would have worn out and/or collapsed on themselves without an insert supporting them.
