You'll find out when you get it done....Wrong. Went through this with XS before I spent money. 150A alternator. To XS925s in parallel. Still a 12V system, just twice the ampacity although the ampacity of each 925 is a little less than a typical regular HD car battery, the mirrored total is more than sufficient. Solved the form factor [size] problem for my power shelf and the [key off] ampacity problems with a 1000W sound system and a few other accessories running extended.
Always good to actually find something. Cheers
I always use die-eletric grease on my ground and power connections to negate this issue. I also 4 or 0 gauge for starter power cable and 4 gauge for my grounds. 8 gauge is way too light duty for powering starter.
