All in the plan. Car will be painted inside and out. Thanks!I counted less than 10 pinholes, but I would agree the best idea would be to cut out the bad area and use small patches here and there.
OP should spray some rust inhibitor too after the work is done, maybe even paint the metal too.
Good stuff dude! Get some pics next time when you can, definitely would love to see it 👌All in the plan. Car will be painted inside and out. Thanks!
If you are a skilled and patient TIG welder: repair.
Otherwise: replace.
I counted over a dozen just in the lower right where the two ribs come close to each other. Once you put a little fire to those, they tend to become big holes.I counted less than 10 pinholes, but I would agree the best idea would be to cut out the bad area and use small patches here and there.
^^ 🤷♂️If you aren't going to cut out the bad and replace with new....I'd suggest duct tape and roofing tar...
You could, but it's still a better idea to cut out the areas and weld new metal in. That way it lasts there.Dumb question, but could you MIG up the bigger holes with small patches, then use some Evaporust to clean the topside of the panel, then use 3M Panel bond for all the pitted and pinholed areas? Panel Bond doesnt absorb water or delaminate like fiberglass does. I am a little curious how it would hold up to the flexing of the floor pan.
