I just got done pulling the chrome trim of my 84 Monte. I have done a pretty good job cleaning up the car and the only rough spots are the bottom of the doors. The passenger door is better than the driver's but they are both almost completely rotted through at the very bottom. I know this is where most G-bodies rot (probably from the poor weather stripping).
I used to paint cars for 3 years and know a thing or two about body work. I was thinking of cutting off the bottom section of the door, welding sheet metal on the outside and forming the inside with fiberglass. Since it is low, I think that I will be able to blend it pretty nicely on the middle body line. The only reason I don't want to replace the doors is the car has a pretty decent paint job on it. Too bad the previous owner didn't take care of these two problem areas before he had it painted!
Anyway, has anyone done this? I think that the outer panel will be easy enough I just don't know how I should build the inner part of the door.
