restoring interior plastic
emoney87
20
my 85 cutlass has a pretty solid interior except for some cracks and scratches in the plastic trim does anyone know how to or a product that will help me restore these if possible, I have a few other older cars with the same issue and am trying to avoid paying for new parts if i can find them at all
MrLightning
281
16
northeast,Ohio
what color are the parts your trying to repair?
lyndon
Oct 25, 2011
52
9
8
kansas city area
I dyed mine from maroon to black. I didn't have the cracks but they probably have some plastic fill at the parts store. I lightly sanded mine down then cleaned them off real good with soap and water. Just make sure they're not oily still. Then I sprayed them with a couple light coats of bulldog adhesive promoter(got that at oreilly for 20 bucks a can). When ur second coat is sticky and almost dry hit it with a light coat of ur color of choice. Keep light coating until u like it. Light coats is a must here, so u don't get the runs. That's it basically check mine out their not bad
emoney87
20
thanks guys i'll try to find a filler and will check out the promoter for sure
565bbchevy
G-Body of the Month
Aug 8, 2011
9,657
12,811
Michigan
When you go to paint it almost everbody on here uses SEM paint on top of the adhesive promotor and when I do any interior parts I finish it off with SEM low luster clear that protects the color and gives a factory type shine.
Every plastic part in my interioir has been painted with SEM.
emoney87
20
your interior looks good man, i will get the SEM dye, I tried the dupont the color was way off n looked like a tuner color.
85GPLef41
2,210
159
Colorado
I need to do my replacement dash board as well. It is burgundy and i need to dye it to grey. how would i find the correct color code? i don't want it not match the rest of the interior.
