Anyone have any experience with this little puppy? I'm looking to replace the radio in Old Blue Hair, since the left channel is completely out, and saw this. 1.5 DIN, supposedly does bluetooth, has additional outs for amps etc. Either green or red lighting....
Looks kinda-sorta-maybe stock. Better looking IMO than a tricked out "mix-effect lighting" 1-DIN unit box stuck in a cheap mounting plate. Kind of expensive but that's how it goes.
I've read that mounting can be an issue, but mounting aftermarket radios is always a b*tch regardless. Anyone?
http://www.amazon.com/dp/B00TE3ZZT0/?tag=gbody-20
The RetroSound Newport is a direct-fit solution for gm vehicles that originally came equipped with 1.5 Din (7-inches by 3-inches) factory radios. Until now, the only way to add a modern radio with modern features to these vehicles has been to install a smaller din-sized (7-inches by 2-inches) radio -- a solution that looks clunky and out of place. The Newport solves this problem: a radio that installs seamlessly into these vehicles, looking like the original radio. This is where the similarity ends. The Newport is packed with modern features, including made-for-iPod/iPhone compatibility and built-in Bluetooth for hands-free phone calls and wireless audio streaming. Two USB ports are provided - one front and one rear - for iPod/iPhone or flash drives loaded with mp3/wma music files. Two auxiliary inputs are also provided for portable devices. The Newport a built-in 25 watts x 4 channel amplifier, and also has front and rear RCA pre-outs, plus subwoofer output, to add external amplifiers. Dual color (amber or green) illumination and back-lighting let you customize the Newport to your vehicle's interior.
