Reverse lights/ Gas gauge not working properly!
digimurda said:
gharris79 said:
Is the rod hooked up from your column to the transmission?
is that rod you're talking about also on floor shifters?
cause no, i dont have anything coming down from the column.
Yeah it's in the engine bay and is on floor shifters. It hooks up to the column and runs down to the transmission.
Wow! i guess thats the problem with the reverse lights, i dont have that rod.
digimurda said:
gharris79 said:
I'm not running mine cause i can't get it routed around my headers.
yea and i think that woul be a problem with mine since i also have headers.
now to figure out this gas gauge issue.
Most likely that is your problem. Wish I could help you out with your gas gauge, maybe something with your sending unit???
for the reverse lights before you remove parts from the car you should inquire first if you don't know what the part does...
I never removed anything, the car had a ratchet shifter when I bought it, I just finished installing the original back on, but noticed it never had that, the last owner must have taken it out.
the linkage is nice to have if the shifter cable ever breaks, you can shift gears with the lower part of the column so your not stranded...how did that car make through a safety with no reverse lites?
Jejeje, "the corrupted state of rhode island" lol
