Ridetech coil overs, Tru-turn system, & muscle bar installed, 87 Turbo T
Undercover87T
G-Body of the Month
Dec 24, 2012
104
133
Westminster, MD
Suspension on the car was tired in some places and was really not that enjoyable to drive. Recently installed a some Ridetech components including single adjustable coil overs, front Tru-turn system and front muscle bar (kept my previous UMI rear control arms and HR Parts rear sway bar). Previously had lowing springs and Bilstein shocks. Still experimenting with different settings, but the improvement in overall handling is shocking 😲.
  • Winner
  • Love
Reactions: 16 users
Turbo Zach
2,534
5,874
That car is gorgeous! If it had maroon interior, I would be in love.
403Olds
534
426
South Central Ohio
Thanks for the real world feedback. I've heard that ridetech was top notch, but always shy'd away from them due to price. Your car looks great. Is the outer tie rods part of the ride tech package?
Streetbu
Know it all, that doesn't
3,734
11,581
Central NY
Yes, the are actually heim joints for tie rod ends and cone with the kit.
  • Informative
Undercover87T
G-Body of the Month
Dec 24, 2012
104
133
Westminster, MD
Wound up dropping to the next smaller front tire (225/50 vs 245/50) due to the tires catching the fender on large bumps and hard cornering. Car also has aftermarket front brakes that increase track width slightly, which contributed to the issue. Afterwards I was able to adjust the front end down another 1/2". No more rubbing 👍.
Reactions: 5 users
scoti
1,978
3,402
Texas
Are the wheels 16x8" @ all 4 corners?
Undercover87T
G-Body of the Month
Dec 24, 2012
104
133
Westminster, MD
81cutlass
4,649
13,565
Western MN
Nice setup!
Does ridetech replace the upper spring perch with a weld or bolt on tab to mount the upper side of the coilover with a bolt or do they mount it in the stock upper perch somehow?
xylorex
305
395
New Orleans, LA
Nice setup!
It goes in the same place as the original coil springs mount. You have to grind down inside of the frame where they sat to make room for the new assembly to pass through
