DEXRON III / MERCON is the superseded fluid for the original DEXRON II fluid. The DEXRON VI fluid is a full synthetic replacement. If you are to use the DEXRON VI, you would need to flush the entire system replacing all the fluid with DEXRON VI. They do not recommend mixing the two fluids.
Dexron 6 is a synthetic blend, not full synthetic. I used Dexron 6 in my 94 4L60E, when I replaced the trans. I also used Dexron 6 in my replacement 2004r in my Cutlass. I used some Dexron 3 with it when changing the governor and fixing the TV cable. Dexron 6 is supposed to be backwards compatible and superior. I have used the Valvoline Dexron 6 with seal conditioners and Mobil Dexron 6, neither said anything about no mixing with older fluid.
Yes, I supply Mobile atf D/M for any vehicles that come into the shop requiring dex II or III (gm dealer). As well as my own vehicles, all which called for dex II.
Valvoline Max Life just says synthetic base oil, just checked. The Mobil says synthetic blend. The price of Valvoline is very cheap at Walmart here. Not even $5 a liter in the 5L container.
it can...if your trans is starting to slip, if that were the case then the bigger thing to worry about would be the transmission frying itself. Low level can cause aeration of the fluid, which can cause slipping but on small drives and usually if it isn't very low you will be ok. How do you know your fluid is low anyway? Did you check it properly?
Well i went to check it while car was running and was back after a half hour drive and it was at the very end of the dip stick in the last section. When the everything is cold the fluid is pretty high up
