i got the car to start but only if i had it WOT
most of us know with a quadrajet if the carb is flooded you put your pedal to the floor and start the car and once it is started you bring the idle down slowly. Sounds to me like the flooding is ongoing so my suggestion above drains the bowel in the carb and will usually dislodge any dirt that is preventing the needle from seating.
If there is water in the gas the gas floats on top being lighter so the car will usually start ok but as your driving the gas and water will mix and cause some issues. If stations had a habit of adding water to their tanks and it's common knowledge they'd be sh*t down.
