S-10 upper and lower tubular control arms
Jackdiablo
22
Louisville, Kentucky
Will 2000 s-10 tubular upper & lower control arms with blazer spindles fit a 1978 elcamino... if so do I need anything else or to modify anything... thanks .
melloelky
4,162
9,569
mass
yes.the lower control arm mount holes in your frame need to be enlarged slightly to accept the larger bolts because the S-10 uses a slightly larger bushing/bolt with their arms.
19,992
I believe you have to drill out the lower control arm mount holes for the larger bolts
19,992
ahh treed!!!!
19,992
Where are you getting tubuler s10 lower control arms from?
19,992
Better make sure they dont lift the suspension
Dont think i have seen S10 tubular lower that didnt unless they are really old
