SBC ENGINE CLAMSGELL MOUNTS
They mount to the block & those are for '72-'81 F body with SBC. OER uses the OEM p/n a lot of times for their parts. Regardless, the frame mounts will be Anchor 2292 or Pioneer 682292.
Someone on here said they used those from OER not OEM. You dont think I can use them?
They won't sit right & won't have everything line up properly. OER is Classic Industries own reproduction line which could confuse some one saying OEM. If you can't get the correct ones it might be better to use the UMI ones.
Okay thanks. The through bolts I got are 3/8 but seems could be a little bigger. Should I use 7/16?
edit: lots of reviews on the summit page for the OER mounts says they used them in a g body. I will try to mount them on the block tomorrow. They fit the clamshell perfect.
Grade 8 flange 3/8"-16x1" bolts are what I used.
