I would use the Holley bracket. It will be engineered to work with the carb.
Looks like they recommend this kickdown bracket......
https://m.summitracing.com/parts/hly-20-45
This bracket might work for the throttle cable. It is carb mounted. It might require a longer throttle cable like a Lokar since the stock throttle cable might not be long enough to reach a bracket mounted to the carb. This bracket is for 4150/4160 carbs.
https://m.summitracing.com/parts/hly-20-88/none/images
