seat belt bolt location
Daca214
647
829
Jupiter, FL
Hey Guys. this may seem like a stupid question, but im not 100% sure of the answer so I will ask the experts..
ok, so when I got my Regal, there were no seat belts except inside the lower panel and he cut them. so they had bolts there, that was easy.
i bought a full set of seat belts, then a full set of bolts off ebay.
as you guys probably know, they are all slightly different in size. even the shoulder bolts, one or two seem a little shorter than the others
does anyone know which specific size bolts go in specific locations or am I overthinking this and it doesnt matter?
O. D. Showtime
3,008
3,537
Regina Sask. Canada
The bolts with the shoulders are used on the upper B pillar and on the inside of each seat on what I call the front inner belts....both locations have to have a little movement. I can't recall if they are the same length in both locations or not. The others should be fairly close in lengths...I've probably got a couple or three sets of bolts and if I can find some time maybe I'll try and lay them out and take some pics......just have a fair bit going on right now.
Daca214
647
829
Jupiter, FL
thank you. appreciate the help
shoedoos
406
403
I've done a search and its either M12 1.75 or possibly M12 1.25 pitch - anybody care to weigh in on which is actually correct?
yourownself
336
38
stoughton, ma
My moneys on them being standard thread, rather then metric, but I’ll find out for sure when I put them to a thread gauge.
shoedoos
406
403
Just did a measure up myself.....for future reference, G-body seat belt anchors are M12 1.75 pitch - which, for all intents and purpose is oddball in the OEM world. I went for a wander through a local salvage yard and almost everything (in metric) now runs M12 1.25 thread on the bolts for seat belts....
yourownself
336
38
stoughton, ma
I do remember them being a VERY course thread bolt. I also totally forgot to measure the thread. Thanks for remembering for me!
Clone TIE Pilot
3,861
2,612
Galaxy far far away
Generally they are torx bolts to prevent tampering.
