FWIW , 68-72 Chevelles had a shifter with an offset stick to come up through the center of the floor/console/tunnel. Might be worth a look
You keep saying you need to score the shorter version of the console used for manual transmission. There is only one length center console on the 78-88 model A/G body Chevrolets in both automatic and manual trans applications (and manual transmissions in the other divisions as well). As others have stated earlier in this thread; The automatic transmission cars up to 85 had the bread box (that housed the ash tray) riveted to the front of the console. The 86-88 cars had a tray (also riveted to the front of the console) with the standard slide out ash tray mounted under the dash. The pictures that I and other posted are the same consoles and would also be the same consoles used in automatic transmission vehicles with the exceptions noted and of course, an automatic shifter in place of the tray insert seen in the pictures.Pagrunt, thanks for the reply. The project is an 85 SS MonteCarlo that came as acquired with an automatic and full console that had been damaged. From the two pictures posted, it looks like I have part of the puzzle but still need to score the shorter version of the console that seemed to be used with the manual trannies. Not particularly interested in cup holders. May try E-Bay or Parts Depot.
Everyone, appreciate all your comments and thoughts. As noted, may have to get creative. The breadbox, apt term for that section under the dash, is available by itself. May elect to leave the replacement factory console assembly unmolested as it is over 30 years old and a refugee from a salvage yard that I picked I can't remember how many years back. May just give it a place on the wall of memories.
That piece is considered part of the shifter assembly mechanism unless you find someone that parted out a mechanism. The Hurst part# for the assembly is 391 8014. There are similar Competition Plus shifters in the older catalog that locate the lever to the center of the tunnel in the same fashion.RibbedRoof, interesting picture of that Hurst four speed you posted. Looks like the standard socket for the stick has been replaced with one that is offset. Do not recall if that part could be obtained by itself. Think I still have the service parts manual kicking around here somewhere. More likely it would be a case of having to buy the whole assembly and swap out what I have for it. $$$$. Still, something to think about.
