Well I took apart a steering column I had to paint all the plastic pieces and used SEM plastic paint/dye as I have read it is one of the best products to use. Sprayed down like 6+ light coats and it turned out great but I have to say it looks kind of textured. Was wondering if this is normal or not cause I was thinking it would be way smoother. The factory paint was nice and flat. Should I put one more coat on it and maybe spray it a little heavier? Also do they make a clear or do I need a clear coat over it or is just they dye good enough?
