You've got a great set up so far (aluminum drive shaft...etc.) why skimp on the rear end? I have an '85 with the stock 10 bolt as well and it is coming out in the Spring. I did a lot of research and settled on a Dana 60 that will bolt right up to stock g-body geometry.
I was originally thinking about the Ford 9"but after doing alot of research came to understand that you can get as much reliability and strength from the Dana 60 as you can with the 9". The 9" goes a step further by allowing you to swap out gears with ease using the 3rd member. Thats great if you're heading to the track, but if you're just trying to cruise the street, why pay for features you arent going to use especially if you dont have to? Apologies if the previous comments ignites the eternal Dana 60 vs. Ford 9" debate...
Now, I havent actually installed the Dana yet, the car is in storage for the Winter. But the last trip that leaky, weak, stock 10 bolt will make come Spring, will be to my buddy's garage only to be replaced by something brand new. Thought I share my rationale as it sounds like we have been mulling over similar questions.
To answer your question that started the thread - yes put a posi rear end in regardless of what style housing you choose.
