its not the t/v adjustment,im still leaning toward the torque converter tho i have a lock up kill switch off for city/on for highway driving but it doesn't change the shudder84GP455 said:My guess would be either the tv cable adjustment or a loose bolt or bolts on the torque converter. When I installed the 2004r in my GP this summer I was also getting a shudder when shifting especially going uphill, and it was the tv cable adjustment was a little off which cured it. You need to have it adjusted so that it doesn't shift too soon, it's better to have it shift on the later side than sooner. It could also be the bolts on the transmission case being loose, that happened to my old Chevy S/10 after a transmission was installed it shuddered like crazy so I brought it back to the transmission shop and they found that they didn't tighten the case bolts tight enough to the block.
