If you are going to upgrade the 4 lites don't buy the hi/lo and the hi's. Buy all hi/lo and when the low burns out you can switch it with the hi/lo you have in the hi spot. You can either bend the low tab up a bit to install the two tabs in the hi connector or pick up a tri connector from your wrecking yard and just put the two terminals in it....that way the tab for the lo beam stays clean. It's alot cheaper doing that way since you don't use the hi's that much and it saves you from having to buy a new lite when a lo burns out.
