small restoration
well since i found the leak, i started working on the floor again. So i started with the hump and i am going to work my way down, but while i was sanding the floor, i seen that the seat mount was rusting so i sanded it and it made holes come out so i just got my drill and drilled the spot welds out and i am going to take it off and sand the whole area and i am going to invest in a mig welder
You may want to try the POR 15 and fiberglass mat repair to that floor to fix it temporarily. Mine was similarly bad, and I used fiberglass resin and mat, top and bottom to cocoon it and slow the rot. I would have done POR 15 instead of fiberglass, but I was too POR to afford it at the time...lol
yea i might use pro15 because this rust remover is just taking its time lol but i think its getting there anyway i broke my wheels to my grinder so i am going to wait till i get another one but the other day i started on the passenger quarter panel window and vinyl top because the rust looked worse and i was right the left side the the channel is gone well almost lol but that whole area is mostly rust and the rear behind the passenger side tire that is in bad shape so i think i will do some fab work till i can can get quarter panel
Yikes. ain't no seal acone (silicone) gonna seal/fix that!
