So I've jus got done with a mini project...1980 Delta 88; Olds 350 5.7, gas. Did an ac delete, and replaced my power steering pump, thermostat/housing, and removed my entire smog system. Also plugged the 8 holes in the block, one on the intake manifold, and hooked everything back up. Fired it...and noticed my valve covers were both leaking...so theres a new project. Question is for the cabin and pulleys. The belts arent jumping and I have no leaks but the GEN light is on and theres a squeak from the pulleys as it runs. My buddy told me about converting from a 3 belt pulley to a 2 belt due to the ac delete and sounds as its running. Common sense would say yes, but I figured I'd ask if this was a step that I missed? When I turn the wheel it squeaks, I notice slack in the belt when the car is off and I check the tension...so just making sure that's what it is. Any and all help always appreciated, peace..
