Whelp, it is, reluctantly, going to be a parts car I think. Maybe it will get a body tub swap at best.
The rear tray is non existent. As in, there is nothing on either side aside from the brackets that help hold the trim panel down.
I hate to do it, I really do. The front and rear windshield aren't even firmly held in. Rather than re-seal they tried to silicone over it which.... didn't really work as time had shown. If I gently push from inside the whole thing is going to come out, your choice front or rear.
I'll probably box up the 88-specific parts. The 3-wire wiper motor, the gauge cluster, etc. Save those for a rainy day. The wiring harness on this thing shows a TON of modifications.
Noticed some black plastic where the cowl trim panel was removed by the PO on either end, not used to seeing this wonder if it was made by someone to, again, work on water leaks? Or was it factory attempt at same.
That is what every Monte I’ve taken apart has, factory black plastic on each end with light silicone to help hold one end in place. Maybe a later year thing added to help potential leaks, I typically only have owned/parted out 86-88’s.
