motor mounts option/ install
Bri guy
845
225
Is this what people are using for solid motor mounts? 1 solid for driver side and 1 rubber for passenger side and thats it?
565bbchevy
9,614
12,683
Michigan
I have only ever ran a matching pair of solid engine mounts with both sides being solid, if you don't want to run solid mounts make or buy a torque strap for the driver's side.
Bri guy
845
225
Huh. I read alot of mixed reviews about using Solid on both.....the 2 common negative comments are too much vibration in the car while driving(hard on the car body) and engine may have wear/tear issues due to absorbing the vibrations more
Bri guy
845
225
Ya I need motor mounts...both are busted. They were brand new normal oem rubber ones....lasted 2 months before they broke
Bri guy
845
225
The pic of the solid mounts are the ones I should use?
melloelky
4,162
9,569
mass
Try polyurethane ones,they're a good compromise between solid and rubber choices.same with the transmission mount.
