spark plug wires?
To test for spark you could use an old transistor AM radio held near the engine and listen for the spark sound in the radio.
Do you know how to test for spark with a screw driver? Or do you have one of these?
No i don't, how do you check with it with a screw driver? How much are those?
if you have a spare plug you can remove the spark plug wire, insert the spare plug and ground it to see if you have a spark.
Do what pontiacgp said or take off a plug wire insert a screw driver into the boot and hold it close to metal while someone cranks the engine over.
You should see a blue spark any other color you have a problem.
