For those of you with the 6x9 wiuth the metra adapters...does teh speaker interfere with the torsion rod for teh trunk??
78mali350 said:metra adapters? mine just dropped in the same holes as the stock ones
which 6x9s did you use?yourownself said:i had to force them in, but it just barely clears once installed.
85 Cutlass Brougham said:The magnets hit the torsion bars in my car. I put some foam tape in between the magnets and bars in mine to keep them from making noise.
walkeraviator said:78mali350 said:metra adapters? mine just dropped in the same holes as the stock ones
Monte Carlos from 81-88 had 4x10s from the factory and require an adapter to run 6x9's
Phoenyx said:walkeraviator said:78mali350 said:metra adapters? mine just dropped in the same holes as the stock ones
Well they're not 'required'. My old Bonneville had 6x9s installed when I got it. They were old ones from the mid 80s. No adapters were used. They just put long screws in at an angle and tightened them as much as possible.
Now this may sound like a crappy set up. But after I installed a 50 watt/channel CD player they pounded hard enough that a few people thought I had a small sub in the trunk.
