I have a few questions about installing the speedway upper a arms.
1.does the long side of the arms go toward the rear?
2.would the tall upper or lower ball joints be a good upgrade?
3.if going with the tall ball joints what specs do you use for alignment?
4.i already have stock type ball joints for the car (86 442) if I use them are there any better settings for better street use than the settings in the alignment computer?
5.are the tall ball joints available from a local parts store under a different application?
6.will tall upper and lower ball joints fit with a stock 15'' 442 wheel?
THANKS!
THANKS!
