Well, the factory front bar will be fine for whatever you choose to do. It may actually be a little too big. The rear bar is also fine for now. Your next step should be finding a fast ratio steering box from a G body (it is the fastest Saginaw box GM ever used, with the stiffest torsion bar!), and some better springs. I would also replace all the bushings in the front end with polyurethane, and replace the body mounts with polyurethane. Now, past that, the major problem with these cars is that the front suspension geometry is *ss backwards to where it should be. This is a complex problem to solve, and as of yet, there is no perfect solution to it. It is where I am at right now. I have the stuff for a tall spindle conversion which fixes the camber curve issue, and since I ordered offset cross shafts, it also fixes the caster issue as well. The real problem that is left is the bump steer issue! I have a few possible fixes for it ( different lower ball joints, dropped pitman arm and idler arm, dropped center link, etc) mapped out, but have yet to do the actual work of running a computer simulation of all possible solutions to find the right outcome. This is mainly doe to me not having access to a suitable program to do it. If anyone knows of a free application that will let me sim the suspension geometry, let me know. As always, I will share anything I find out on the forum for the benefit of all.
