1985 Monte SS
~300 crank hp 350cid
ZF6 speed from a '96 Vette (also have a "black tag" '93 unit that is stronger and will get built)
8.5" GN rear w/ 4.10's, Posi, Moser axles
~3-4" drop, car looks good but doesn't handle like it should
17" wheels, 8" wide up front and 9.5 in the rear. Will get some 12" wide wheels for the rear and 9.5-10" wide for the front after building my next chassis
(Thanks to Doug Austin for these awesome shots!)
This race was shortly after getting the car back together for the first time in over a year. I took the body off the frame to do a bunch of rust repair in the body mounts, floor pans, and trunk pan.
Frame body mount repair
Body side repairs
Spare tire block-off panel
Sandblasting
Seat mounts (car was a solid bench originally, needed inner mounts for the buckets)
Go-faster holes
The ZF6 doesn't exactly "fit" in the trans tunnel... so I had to mod it.
Everything is butt welded. The floor pans, trunk pans, trans tunnel. I had rust in a lot of the lapped pannels because the seam sealer failed after 25+ years. I didn't want to give water any new places to hide.
POR15 on top and bottoms of floors
Cut down the body mounts to lower the car a bit.
Extra room from the minitub. I plan to build a whole new chassis, so no point in going crazy on this one. I just fixed the body mount holes which took a day, so that I can enjoy the car while I build the new chassis.
I guess this is a good spot for a little background on me... I'm a big nerd (at least that's what the driver's at work call the test engineers.) I do vehicle testing for the Army. I graduated from UMD with a BS in mechanical engineering and while I was there I tried to focus on automotive as much as possible. I was on the FSAE team and took a vehicle dynamics course. Since working as a tester, I have been able to go to a few SAE vehicle dynamics classes and visit places like TRC.
There is a lot that I want to do to the G chassis, and I will try my best to document it as I go. I'm going to start with some simulation using a Matlab script that I wrote to simulate a double wishbone suspension. The front suspension geometry will be completely re-worked and the rear will be changing to a 3-link with a panhard bar. Hoping I can still sneak my exhaust out behind the rear tires when it's done. I don't think I could pull that off with a Watt's link. The chassis will allow me to run big rubber all around too, and I should be able to build a good bit of tuneability into it. Planning on using adjustable spring cups if not coil-overs. Definitely needs a lot of work in the steering department and a faster ratio box. The steering geometry is built into my simulator as well. This is all going to be a huge challenge, but I think it will be very rewarding when it's all together.
I also have a 010 1970 high Ni 355 engine to go in the car. All forged rotating assy, 215cc Dart Pro1's (~8.5:1), and I plan to twin turbo it with EFI run by a megasquirt. I dont have the induction or snails yet, I figure the chassis should come first so I don't twist the car up or wreck it with all that power.
The car hasn't had an interior in a little while... thinking of insulating the floor, putting down carpet, and making aluminum door panels. I've been working on a fiberglass dash and console too. Here it is before the glass, it's the stock dash with marine pour-foam added, a few pieces cut off too. The console was from scratch out of a cardboard form.
![](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2FFSC_AX_1_zpscab5910c.jpg&hash=d2d2e4bb1347f375d1089d14d7edcc64)
![](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2F201307070019_zpse48a8cc8.jpg&hash=38e86153bd1845fd3ab7c38b0caf4472)
![3e3fef9b.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2F3e3fef9b.jpg&hash=bca384e2770f4e02e6ecac6a6b043f04)
![2c67a496.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2F2c67a496.jpg&hash=9a25c70567f50382dbbf36e80ee1b146)
![bbbaa01b.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2Fbbbaa01b.jpg&hash=f1040f3b9a42022426d7917e1dc56b38)
![8a1c27cb.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2F8a1c27cb.jpg&hash=57ca23482e60357973d3d576c77e1f45)
![9A73B558-EF6B-49D3-9E3D-16CDEE7DA07C-5330-00000834FA2A8EF4.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2F9A73B558-EF6B-49D3-9E3D-16CDEE7DA07C-5330-00000834FA2A8EF4.jpg&hash=654f1b205b5d97445741d8dd1ee59048)
![E8E3ACC3-F4C7-43B1-B191-840602A60454-9649-000010B615CCA8C8.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2FE8E3ACC3-F4C7-43B1-B191-840602A60454-9649-000010B615CCA8C8.jpg&hash=be6f97d488141d43498b34fc53386573)
![C2181FF7-435A-4101-A084-B83ADB2DD39D-2305-000001EA6CA7B788.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2FC2181FF7-435A-4101-A084-B83ADB2DD39D-2305-000001EA6CA7B788.jpg&hash=3605d0804c956d13e10a4f53c5b5fd2d)
![549C5297-9684-40F4-AD2F-EC2F5848FCB6-7515-000008B34043C378.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2F549C5297-9684-40F4-AD2F-EC2F5848FCB6-7515-000008B34043C378.jpg&hash=85e8af9a13a9c2a6bd5db264e49e5554)
![B15F827B-E354-469D-B080-974C97D30B59-9662-00000A6A0BECDEA7_zps744e096f.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2FB15F827B-E354-469D-B080-974C97D30B59-9662-00000A6A0BECDEA7_zps744e096f.jpg&hash=6bb7310e375cae58adb315a283ddbbbe)
![879B2C5E-7B6F-4C67-8CF8-27EBE764286C-11637-00000B8725C29089_zps5d828465.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2F879B2C5E-7B6F-4C67-8CF8-27EBE764286C-11637-00000B8725C29089_zps5d828465.jpg&hash=2c09fd87e0af58e43c1eda97eeca2b38)
![735E6E7D-EDCA-47D0-8F42-D01A39FBED47-11637-00000B872E347A9A_zpsa565b861.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2F735E6E7D-EDCA-47D0-8F42-D01A39FBED47-11637-00000B872E347A9A_zpsa565b861.jpg&hash=a4325efef6593964d49a46857a3bca85)
![9775B799-508D-4172-9FC0-E8A0C5E58EC7-11637-00000B876CE16EAA_zpsab9d1b41.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2F9775B799-508D-4172-9FC0-E8A0C5E58EC7-11637-00000B876CE16EAA_zpsab9d1b41.jpg&hash=e637d814a3005637025a5d9f144e348c)
![C02F8CD3-1CD5-4721-8E12-1B4AE3E575BE-11637-00000B879975A019_zpsc889ba7d.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2FC02F8CD3-1CD5-4721-8E12-1B4AE3E575BE-11637-00000B879975A019_zpsc889ba7d.jpg&hash=a2c397c15501ff18ea3c781310f7885d)
![827AF0B2-34A2-4D7B-87C5-070DC092BAD3-11637-00000B87A0EF152F_zpsbba9d879.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2F827AF0B2-34A2-4D7B-87C5-070DC092BAD3-11637-00000B87A0EF152F_zpsbba9d879.jpg&hash=7617b4c758212c8b689bbd2f7943e5e5)
Body side repairs
![236B6927-2FD6-435A-8918-DE3111B12ABD-6799-000005891FF981EA_zpsabfb5f7f.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2F236B6927-2FD6-435A-8918-DE3111B12ABD-6799-000005891FF981EA_zpsabfb5f7f.jpg&hash=2800e8746f64a28ba689ea45f9aa9d6f)
![5113AE28-450F-4509-ACBD-F1FCA7C0AE04-6799-000005893A3C9B22_zps8d3420bd.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2F5113AE28-450F-4509-ACBD-F1FCA7C0AE04-6799-000005893A3C9B22_zps8d3420bd.jpg&hash=151a8452e64a95a0cf248982745aa2a3)
![3F44CEFF-9A32-4B66-86CF-19FC1AFA7FF9-6799-00000589422C1911_zps210d8a1f.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2F3F44CEFF-9A32-4B66-86CF-19FC1AFA7FF9-6799-00000589422C1911_zps210d8a1f.jpg&hash=1a7476ff7007a44893b8ea53a15fdbb0)
![498CC34B-9395-4ED8-83FD-C8F9881A5189-11416-00000A745510E1EE_zpsf5b615ff.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2F498CC34B-9395-4ED8-83FD-C8F9881A5189-11416-00000A745510E1EE_zpsf5b615ff.jpg&hash=c2fff38899e865074747c554d2aa53af)
![B89F206D-87BA-4308-95A6-CD7C4065FCE6-124-00000001919C95F1.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2FB89F206D-87BA-4308-95A6-CD7C4065FCE6-124-00000001919C95F1.jpg&hash=e88c09086985914cc71de9f9a0a8fdd8)
![6E5270FD-7391-4567-B38A-7926F0E5ADD1-1042-000000D6F82C7C32.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2F6E5270FD-7391-4567-B38A-7926F0E5ADD1-1042-000000D6F82C7C32.jpg&hash=5f27b56af85cbbfb78e67f481e5440b7)
Sandblasting
![058CBEE0-4D66-4861-8FB6-2CC54594E9D2-18095-00001365C6504A71_zpsc2b646c0.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2F058CBEE0-4D66-4861-8FB6-2CC54594E9D2-18095-00001365C6504A71_zpsc2b646c0.jpg&hash=3f9b5b1534527e3744809a16fbd72a08)
![13497CCB-8655-4109-B36E-6E9CE4AC7C98-18095-00001365DB5A40CC_zpsd0587c33.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2F13497CCB-8655-4109-B36E-6E9CE4AC7C98-18095-00001365DB5A40CC_zpsd0587c33.jpg&hash=ba2fab105f1c3f4350e9720f8cc1a018)
![CE1E8B8A-7C00-4CD6-AE07-2A3BF81F4126-19220-0000147A28B3D374_zps86e72a5c.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2FCE1E8B8A-7C00-4CD6-AE07-2A3BF81F4126-19220-0000147A28B3D374_zps86e72a5c.jpg&hash=d69703ba9d6b9f6571980a3801cdb335)
Go-faster holes
![95EABB5E-67FC-46DB-B402-DC1521F2EFB4-19952-00001518640998A8_zpsede94b4b.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2F95EABB5E-67FC-46DB-B402-DC1521F2EFB4-19952-00001518640998A8_zpsede94b4b.jpg&hash=ba83cb9f030da50a160b5a7779daa267)
![695A00DF-5248-4C5E-A687-FA1B7108234E-20309-000015818B5D0741_zps5c43a990.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2F695A00DF-5248-4C5E-A687-FA1B7108234E-20309-000015818B5D0741_zps5c43a990.jpg&hash=8cc16dbcdbda3f1325d379c3f1f5b6a4)
![914C89B6-543E-4803-B3C2-0528E709AA6A-20659-00001636998C7035_zpsa1b2c40e.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2F914C89B6-543E-4803-B3C2-0528E709AA6A-20659-00001636998C7035_zpsa1b2c40e.jpg&hash=c8c33dc510eac4b9b37d302bb0a785dc)
![0B6826CE-FDDC-465E-AB63-EB91115792D9-23871-0000195DF7AC8F05_zps8ebeaa58.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2F0B6826CE-FDDC-465E-AB63-EB91115792D9-23871-0000195DF7AC8F05_zps8ebeaa58.jpg&hash=3888a8d1ad98c234b1adb0cdcced5ad0)
![F553444A-3745-4947-85FE-EFEE87B5A19A-23871-0000195DE4BDF92A_zpsb520f8ac.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2FF553444A-3745-4947-85FE-EFEE87B5A19A-23871-0000195DE4BDF92A_zpsb520f8ac.jpg&hash=8bab80b2be7708e47f5ebe5a1c38fccc)
![C8A29492-6384-427D-BD22-EF64B91D8AC4-1848-000002A686A96E05_zps488f528a.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2FC8A29492-6384-427D-BD22-EF64B91D8AC4-1848-000002A686A96E05_zps488f528a.jpg&hash=62d5a7f2cf990bbf6c64721c35e157a4)
![369C2CC7-803C-4730-8452-DD89A86A44C6-1848-000002A631AF9397_zpsde21076d.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2F369C2CC7-803C-4730-8452-DD89A86A44C6-1848-000002A631AF9397_zpsde21076d.jpg&hash=f4e272697b828a194897169f1096e6d3)
![DartIntake.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fsickspeedmonte.com%2FDartIntake.jpg&hash=19a963ca27e7f96c948593377baa77ba)
![PistonsAndRods.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fsickspeedmonte.com%2FPistonsAndRods.jpg&hash=5d18d0850d6d1c0bead1776ed5193e20)
![fbd44310.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2Ffbd44310.jpg&hash=34ac939f0f690cb9445cf6fd45f135f8)
![f4a0849a.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi20.photobucket.com%2Falbums%2Fb221%2FbadaSSMonte85%2Ff4a0849a.jpg&hash=9620a8a03f59d9f35373874a0b3f8a05)
