Stalls at idle in gear
Dieselcamino
11
2
35
Hey guys, I have an 87 el camino, 305 automatic, 75k miles (father bought it new) maybe gets 100 miles a year but trying to drive it more. This year I've been taking it out and it has a lot of lag around 2k rpm and at stop signs it stumbles and dies. It will idle in park/neutral though. Not sure if it's a carb issue, timing? Had the carb rebuilt about 5 years ago
Check for vacuum leaks and bad accel pump seal.
Reactions: pontiacgp
Sounds like a couple things. I would unplug the egr valve to see if it helps. Like above said look and listen for vacuum leaks. Sounds like a carb issue but still could be many other things
Does it feel like a manual transmission that you did not push the clutch in on and does it seem lazy after the 1-2 shift?
My 88 SS Monte Carlo had this issue and it was a bad torque converter lock-up solenoid in the transmission. The converter would lock up on the 1-2 shift and would stall the engine when coming to a stop.
Purchased the solenoid through a local transmission shop to fix mine but TCI now has them available through Jegs and Summit.
pull the squirrel out of the catalytic convertor
Going through the gears it feels fine, It's got a sluggish spot right around 2000rpm when driving but if you lay into it and get it above that it opens right up, and when you coast to a stop it sputters for a few seconds then will die off, if I feather the pedal a few times I can keep it going, it will stumble and die in drive or reverse (makes it a pain maneuvering it back into the garage)
Took that cat off years ago so I know that's not plugged up, cant find any vacuum leaks but I'm going to borrow a friends smoke machine
Played with it for a few hours this afternoon, checked the timing and it was right around 0 degrees where the factory sticker claims it should be, no change
Checked the gas cap as a friend had suggested and that's fine
Looked for vacuum leaks and didnt have much luck, going to try and borrow a smoke machine over the weekend
Sprayed down the carb inside with carb clean( willing to try anything)
Also starved the motor of air till it just about stalls a few times ( used to work great on my lawn mower) but no change
Still idles a bit on the low side and stalls out when put in D or R even the draw of the power steering pump aids in its stalling
After more playing I've found it will almost idle in gear when I have the air on, when I shut it off it will almost instantly stall out, I'm guessing a vacuum leak somewhere,
Pretty sure that is just the idle stop solenoid bumping up the idle keeping it running,
