Your choke seems fine, rule of thumb ive found is about an 1/8 inch gap gets you in the ballpark. Sounds like to me, accel pump and your secondary barrels are too loose. Classic issues with the quadrajet. Those secondary's are pretty big and will gulp some air when called upon. Enough to stall you out, especially if the accelerator pump isn't up to par. Start with a carb rebuild..
Thats what I was trying to diagnose if its a tuning issue or if it needs rebuilt. The OP is very new to working on cars so Im sure he would not know where to start looking for somebody to rebuild the carb. Perhaps you will do it for the OP.Start with a carb rebuild..
That does look like its close when its cold, after running 5-10 minutes the choke plate would be standing straight up.i did not drive it cold , usually let the car run for 5-10 mins before driving .
it has an electric choke i know that, but i don’t know how to tell if it’s working correctly
there is power that is going to the choke thermostat , checked with a voltmeter
That is a Dualjet, the smaller 2bbl version of the Quadrajet. It only has primaries, no secondary. Looks like someone removed the anti-tampering plug for the idle air bypass valve.this is how i found the choke blade, cold engine.
is that partially open? should it be closed?
