Yes. You are closing in on it. Very good. Now you see how it works and can adjust it properly. Being colder weather,it is likely wanting to be closed a tad more. Don't forget to do as pontiacgp suggested. If there is a thermal vacuum valve in the ditributor vacuum line it should be closed (no vacuum) until the motor heats up. Two vacuum lines that meet into one? Sounds like ported (carb) and manifold (manifold) vacuum meeting at a vacuum regulator valve (VRV) that gives about 10 inches of manifold vacuum to the distributor, then as the carb opens ported vacuum takes over the advance function. This can be tested with a vacuum gauge.
