Starter not turning over
rogus
300
83
what would happen if I ran a jumper from the purple wire on the solenoid and then momentarily connected that wire to the positive post on the battery? Basically connecting the solenoid briefly to the battery. Should I at least get a clicking sound from the starter?
rogus
300
83
would it help to jump the purple to red wires on the ignition switch or purple to brown?
78Delta88
703
410
SW Arizona
Something in the work performed is causing the issue. Just retrace your steps and in there you should find the cause.
rogus
300
83
I think I should declare myself declared non-compus mentis....I didn't have the switch in the located correctly on the shaft.....
