That will be next to test under dash, but logically don't understand why that would be the problem. 3 wires from solenoid (1 to ignition switch? always hot, 1 to headlights? always hot, and 1 to fuel pump relay always hot.) Seems something should work inside car even if it is the switch because switch is not getting all the power.Ignition switch
Yes, should have no effect, but good question to cover all the bases. Nothing inside, but a week or so ago, replaced supply and return fuel rail O-rings and had to remove PFLS connector from alternator (CS!30) to do that. Replaced connector and car running after that. After O-ring replacement, decided to add an alternator sense wire to see if could boost voltage at idle. Added 12g. wire from PFLS connector stub and connected to + battery. Not the ideal spot, but car running after that and idle voltage up slightly.. Connected or not, don't believe that should have effect on cranking, but at this point willing to accept any suggestions.Have you had ANYTHING apart before this started ? Inside or under the hood ?
Can't answer that question without a complete wiring dive, which I'll consider as a last resort. But when looking at the Gbody wiring diagram for 78-87 Elky, it shows 2 wires from solenoid to: (1) ignition and 2 (headlights). My 3rd wire is likely to the TPI fuel pump relay. I purchased the car 10 years ago with wiring already done, so have no clue. Regarding the PFLS connector which I don't believe is the issue, before the sense wire have only one other wire which has not been touched. That's the 'L" wire to the lamp/volt gauge. I have a gauge and no lamp, so wire has a resistor in it to ensure the resistance of the lamp is met. Has been that way forever.Not sure how your car is wired compared to my 81 but one wire from my alternator went into the factory splice that was in the harness on my intake. Hard to remember how the wires ran but I think one went to the starter and the other ran to the bulkhead connector. Not sure but could the issue be one of those wires ?
Yes, going off test results with very sophisticated machine. Battery is good. And BTW, Battery Source's best Size 78 battery is only $119 compared to the box stores $159 and up and has better specs. Plus has 6 year warranty, 2 yr. no question replacement, with remaining 4 yrs. prorated. Big box all 2-3 yrs. prorated only.I quit buying Carquest batteries for the very same problem you are having. Did you try a different battery, or are you going solely off load test results?
