Thanks. I am using yokohama 245/40/18 at all 4 corners90hurst/oldsguy said:your engine looks very good . what kind of tires are you running
dr78442 said:Intragration said:Hey, good to see your progress, and that everything worked out with the pushrod problem. That is one clean install, very impressive. The whole car looks great. Have you had a chance to drive it with the new motor yet?
Thanks! The 455 is running well my pushrod trouble was caused by a part miss match. Mondello sold me 3/8 pushrods and 5/16 rocker arms. I replaced the rocker arms with comp cams rocker arms for 3/8 pushrods and my broken part problem has gone away. I have been driving the car . It feels very comparable to the BBC that I had before. I am happy that I went back to Olds power
Anubis said:dr78442 said:Intragration said:Hey, good to see your progress, and that everything worked out with the pushrod problem. That is one clean install, very impressive. The whole car looks great. Have you had a chance to drive it with the new motor yet?
Awesome build. In your video, it sounds like your idle is quite smooth (which I want for my next build). How did you choose your cam? Also, are you using Accell DFI engine management? If so, how do you handle making changes to the set up? I put Accel DFI on my Z71 LT1 build and like it but he software is $1200 :shock: :shock:
