I have a service manual and the procedure to change the shifter bowl to a normal non shift bowl looks a little intimidating. Are there any of those out there which have attempted to changing this bowl and what to look out for when doing so?
LS1GN said:Not sure what you mean by 'bowl". The bowl which holds the actual shifter on the column? Yes, it is a pain so I just took the shift lever off.
Yes, it is redneck. No, most people don't notice.
LS1GN said:I figured I'd leave it in "low" so it would be out of the way, then I couldn't get the key out! :shock:
There was a guy on the El Camino forums who grinded the bungs off the bowl and filled it with some JB Weld, sanded it down and painted it. Turned out really nice. Is the bowl you got aftermarket?
Mike P said:One of the pains is getting the wiring in and out of the column. Just take it slow and don’t force anything. I really suggest you pick a day when you have nothing else to do or places to be so you don’t feel rushed doing it (especially if it’s your only car). It might go very smooth, but then again you could run into some of those aggravating little problems that often crop up.
I’m one of those guys that cuts the nubs off and fills and paints them. I started out doing it 20 years ago on 50s cars that we were converting to floor shifts when we wanted to keep the original column (there were no smooth shift collars available back then). For me it’s a lot easier (and of course cheaper) especially on a tilt column. Properly done no one can tell the difference.
