Steering Column Issue
tcolvinOH
41
4
8
Ok y'all, have a bit of an issue that Im hoping you guys can help with. Im in the process of putting together the steering column after tearing it down to accomplish 2 things - 1) repaint the column to match the rest of the car and 2) replace the turn signal switch. I disassembled down past the steering column housing (completely removed the housing, including the lock cylinder and all of the screws). Im in the process of putting the housing back together and I have a couple of pieces that I cannot identify where they are located. I know the back piece of plastic somehow fits in the steering column housing, but I cant seem to figure out where. The other piece, I have no recollection of as well.
Any thoughts? A breakdown of the column would be helpful as well, but not required. Ive searched on Google already, which has come up short. Any help would be appreciated.
That was exactly what I needed! Thank you so very much. I found a couple of issues when putting everything back together, but it all went back together, so Im pretty happy about that. Have to tear it back down again. The pictures that were included were perfect.
Thanks again!
