If I recall, the ball bearings were loose and I just added grease to hold them in place. I didn't mess with replacing the race.
If you're dead set on replacing the race, I suppose with the ball bearings removed, you can gently pry the race out with a flat blade screwdriver. If the race is not galled and is in relatively good shape, just reuse it. I would inspect it first and make an assessment.There was no way to do that with mine. Bearings everywhere. Plus i had the kit to replace them. Might as well do it
True. I believe there's an inner race that sits inside the balls around the shaft (say that in public 5 times) as well and the spring to hold all that sh*t in.I would assume the bearing would sit flat in the "holder" and that plastic would be facing out...
