Thank you. Havent seen this video beforeI did this job last year using the video below. To save you some time, it starts at 22:00.Good luck!
Made an edit to the time stamp. I originally thought you were referring to the ignition piece.
I thought about doing that. I forget that dang shifting collar can move and wont let me start the car if it does.
Will any 80s gbody steering column fit directly in?the shifting collar is still attached to the rods when you have a floor mounted shifter. The floor shifter keep the transmission gear selector lever in place and the rods keep the column in place. The only reason you need to keep the rods in place is that if the column has to rotate so you can remove the key and lock the column.
Yes but keep in mind the differences of certain years. As we all know '78 columns have the splined lower & the earlier method of ignition lock retention. The '79-'81 are the same as '82-'88 with the lock screw to retain the ignition lock but doesn't have the column wiper switch. The '82-'88 columns are the "fits all" ones as they can use either the wiper switch turn signal lever or the non-wiper switch lever.Will any 80s gbody steering column fit directly in?
😳 ok. Only look for 82-88 columns. Thank youYes but keep in mind the differences of certain years. As we all know '78 columns have the splined lower & the earlier method of ignition lock retention. The '79-'81 are the same as '82-'88 with the lock screw to retain the ignition lock but doesn't have the column wiper switch. The '82-'88 columns are the "fits all" ones as they can use either the wiper switch turn signal lever or the non-wiper switch lever.
