Stereo Crackles
jordanfr13
Sep 23, 2009
89
32
Morris, MB, Canada
I recently installed a high end pioneer deck in my car, and when I have the car off but the ignition on, the stereo sounds great. However, when the car is running the speakers crackle. I seems to only happen when the car has been running for less than 5-10 minutes, then seems to go away. Anybody know what might be happening?
Are any of your speaker wires touching each other? Is your cd player stable?, is it moving while driving? If its sliding around there may be a problem. Maybe you have a speaker wire tied to something else. Just a few possibilities. trying to help.
Thanks, but it's stable, wires aren't touching etc. I'm thinking it must have something more to do with a short in the alternator, alternator ground or something like that
pontiacgp said:
It sounds like it's a ground issue and your getting engine noise.
I agree. Where are all you stereo components (deck, amp(s), etc.) grounded?
All I've done is replace the stock deck with a cd player. I'ave also taken out the 4x10's and put in 6x9s, but the old speakers crackled too
How did you wire in your deck? Did you buy one of those kits or did you splice it yourself? And also, are you using the factory speaker wire, or did you replace it?
and did you ground the chassis of the radio?
I bought an adapter, which still required splicing. The pice that holds the stereo in place is plastic, so I'm assuming it's not grounded that way..
there is usually a stud and nut in the back of the head so you can put a brace if you want. I would attach a wire to that to ground the chassis to a good source and see if that cures it...
