every application will be slightly different but on average , more is not better for low end Tq. maybe loudness but not TQ. if u r going more than 10% over manufacturer size on a stock engine u r making things worse, especially w/o a tune
Area of a circle is Pie x R squared
so a 3 inch single system is 3.14 x [1.5x1.5]=7.065[overkill on stock 80s 305]
a dual 2.25 system equals 3.14 x [1.125x1.125]x2pipes=7.94[way overkill]
Unless you put a blower on that dusty old 150 hp 305 i think, no i know, dual 2.25s is overkill, dual 1.75 would be sufficient and not lose any scavenging effect and low end tq.
this is exactly what my cutlass 305 had on it, no cats, just dual 1.75 flowing thru glasspaks
one shitty thing about stock old 305s i noticed in my teardown was that warmup valve in passenger manifold, that even when open had to be blocking a very signifcant amt of exhaust flow, should be removed if you value power over faster warmup.
2 smaller duals will always give you a higher pitch, more poppy raspy sound.
I put my 300 hp LS on a single 3 inch just for the burbly , low pitch Big Block sound, and it does sound like a BBc and im not sure i wouldve saved any lowend tq going with single 2.75 inch since my exhaust tube is so short, only 3 feet.
if you have a stock 305 and want bassy burbly Big block sound , go with a single 2.5 inch system and maybe a much larger tip, like 3-4 inches.
ive done this exact trick on my civic, i cut the muffler off entirely and just welded on a 14" long 4 inch tip and it made the 1.8L 4 cylinder sound like a 3 L v6
im sure all my neighbors hated it when i got up at 630 am to goto work , cuz for that first ten sec at startup it was extra loud.
not as loud as my LS with single chamber muffler and 3 inch system but now i live more rural so less neighbors
removing cats and resonators also makes a big difference on sound
some of the best sounding cars have longtube headers, no cats, no resonators and straight thru mufflers.
