What are some tips you guys have for getting the most HP from a stock 307? I've already cleaned out the cat w/ straight pipe, advanced the timing, and am running a K&N filter. Thanks.
STL84Calais said:What are some tips you guys have for getting the most HP from a stock 307?
Blake442 said:STL84Calais said:What are some tips you guys have for getting the most HP from a stock 307?
Replacing it with a 455!
jonnyslick said:Why won't they make HP? It seems with new heads, intake, and cam on a good rebuild with a tune it should be able to make more? I mean 289 and 302 fords can make some good numbers, 327's can make good numbers. So why is it that the 307 (and even the 305 chevy) you usually never see making good numbers (meaning like 350hp or more)?
Biggwaukegan said:I say this....get a old carberated chevy 350. 4 bolt main of coarse. then have the shortblock done...bigger cam and have the heads done too. then throw in some goodie like edlebrock carb, headers, bigger oil pan, intake and youll be easy 350 or more. combine that with new true duals, cats and i bet youll be even closer to 400hp than you think! Im doin that on my 86 cutty. got the 307 running good now but the 350s goin in by spring. :lol:
