well, I've been looking all over for suspension upgrade parts on the cheap. I found some new S10 coil springs for a 1992 2.5l S10 at AutoZone for $65. I am pretty sure they are moog because the central portion of the part number is "5660" FCS5660S is their part number. So I am hoping for a 1" drop at least over the cut diesel springs I have in my car now. The spring rate on these 5660 is about 640 and the diesel springs I have in the car now had a coil spring rate of about 350 stock, but I think I cut about 2" off them, so I am not sure what the rate is now. I bet the rate is close to the 5660's. I will start of by putting the front springs in stock and then decide if I need to cut them.
I found a 2 door S10 blazer 4x4 the other day in a junkyard and for $25 I scored the rear sway bar (23mm) and all the hardware- I just need end links right now for the sway bar. For the rear suspension, I plan on buying those cheesy lowering brackets that simply collapse the coils together with saddles like a muffler clamp, and big bolts. I mainly want to use those to figure out how much I need to lower the rear of the car after the front is done. I won't leave the "lowering" brackets in for more than a couple weeks hopefully. Depends on when I can get new rear springs.
The car is at my buddies house getting body work done right now- He does bodywork and paint at a restoration shop that only turns out $50k + builds. Nothing they do is a half *ss. He said my car will have a $10k body and paint on it so I want the body to sit low enough to get rid of all wheel gap, and hopefully help it drive a little better. I want flat cornering, and driftability 🙂 it's not going to an autocross king, but a fun cruiser
