Nope. Look, I've talked to Mark on the phone multiple times. He never said this. At rest on a stock height or lowerer car (or even on a slightly raised car) a Tall ball joint is going to sit pretty close to the center of its travel with a stock arm.
Other than some caster angle, the balljoints sit relatively flat in a stock stamped steel arm, and won't bind, unless you put long travel off road shocks in front... then they might bind in full, airborne, droop.
The only real issue with stock arms is they are 1/2" too long, so they have to be shimmed at least 1/2 in with tall ball joints. That's it. I'm sure someone with a drill press could whip up some 1/2" spacers and then even that isn't an issue.
