My car has a 5.3 LS based truck motor paired to a 700R4 that the prior owner swapped in. I am going to swap out the 700R4 for a 4L80e 2wd.
What parts should be replaced and sourced prior to the swap?
transmission crossmember
transmission mount
transmission slip yoke - how to size this?
dip stick - any suggestions on which one?
U joint - how to size this?
output shaft seal
torque convertor
6AN PTFE lines and connectors
main transmission harness from PCM to transmission
speed sensor harness from PCM to transmission
cut "ears" off the transmission to ensure enough clearance for install
drive shaft - this needs to be measured after I have the transmission in, but I estimate it will need to be 2" shorter than the current one. What other measurements should I take into account when getting a new drive shaft?
what is needed to connect the drive shaft to the rear end? new u-joint? yoke?
How would you check a used 4L80e to see if it would even work before installing it? I was going to drop the pan and see if I could find any major debris, but other than that I am going into this blind.
Sorry for the newbie questions, I have never swapped a transmission before, let alone from one model to another model transmission.
transmission mount
output shaft seal
torque convertor
