Has any one ever ised the sway bars, rear springs and frame stiffners off a Montess and swaped them over to a malibu?
results?
issues?
Thanks,
kevin
results?
issues?
Thanks,
kevin
85 Cutlass Brougham said:Well, the MC SS has the F-41 handling package as part of it, so you already have the good stuff on it. Just swap it all over to the Malibu and you should be good to go. Don't forget the steering box, as it has a faster ratio and more feel than a standard G body bod.
LS1MonteSS said:I was thinking about doing away with the steering box all together and do a power rack set up and also loosing the belt driven P/S pump and going with an electric P/S pump from a Subaru XT6 or Toyota Prius.
Also along those lines I'm going to use an electric AC compressor which will really clean up the front of the motor and free up some ponies.
I have still been playing with the idea of an electric water pump then the only belt driven item will be a 130 AMP Alt.
