565 and 454 - I understand the system you guys are employing. And it will work great, but the point I was trying to make (and I should've been clearer) is that you want the pump to shut off when the motor is off in case of an accident and to save the pump from running of the key is on and the engine is off.
Wiring in an oil pressure switch works in a similar manner but kills power to the pump when there is no oil pressure, what will kill power to the distributor when something happens?
One wire goes to the pump, one to the start circuit, and the other to the ignition circuit. So, when there is no oil pressure, the switch connects START to PUMP, and as soon as you start cranking it runs the pump. When the oil pressure comes up, the switch connects IGN to PUMP, for normal running. When oil pressure goes away it again connects START to PUMP, and disconnects IGN from PUMP, so the pump shuts off.
